Archicad C++ API
Is it not possible to create line dimensions, etc. in the worksheet using the API?
LeeJaeYoung
The lines studied with the element_test code are not created in the worksheet.
How can I create one?
AC27 on window 11
1 REPLY 1
Hi!
My guess is, that you first have to switch to the correct database with the API.
Check out ACAPI_Database_ChangeCurrentDatabase (AC27).
Also if you want to have the menu item available over a worksheet window, you'll need to use the ^EW control code as documented here:
https://graphisoft.github.io/archicad-api-devkit/md__common_doxygen_files_2_articles_2_required___re...
