Library Part - array - GSHandle
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2016-02-22
08:29 PM
2023-07-12
09:11 PM
Doreena Deng
2016-02-22
08:29 PM
Hello there.
I have been trying to create library parts using the C++ API. However, I have encountered a problem when creating parameters for said library parts.
I can add parameters that are NOT arrays, using the different types (APIParT_Integer, etc...).
However, when I try to create parameters that are arrays, I do not seem to be handling the value.array correctly (GSHandle).
I'm trying to allocate memory for it, but my add-on keeps crashing.
Here is an excerpt of the code that is causing problems:
Can someone help?
Thanks in advance,
Xylios
//... (*addPars).typeMod = 2; (*addPars).typeID = APIParT_Integer; (*addPars).dim1 = 5; (*addPars).dim2 = 1; (*addPars).value.array = BMAllocateHandle(sizeof(GSHandle), ALLOCATE_CLEAR, 0); *(*addPars).value.array = BMAllocatePtr(5 * sizeof(int), ALLOCATE_CLEAR, 0); if ((*addPars).value.array == NULL || *(*addPars).value.array == NULL){ ACAPI_WriteReport("NOPE!", true); return; } for (int j = 0; j < 5; j++){ (int)((int *)*(*addPars).value.array) = msg.intarrays(intArrayCounter).lst(j); } //...My question is how to correctly work with the array of the parameters.
Can someone help?
Thanks in advance,
Xylios
Labels:
- Labels:
Add-On (C++)
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2016-02-23 06:09 PM
2016-02-23
06:09 PM
Did you look at the \Examples\LibPart_Test\Src\LibPart_Test.cpp in the SDK samples folder ?
There is an example for creating lib parts.
In the method "Do_CreateLibraryPart" there is a code for creating simple parameters and also array parameters.
Here is a part of the code but the best is to look at the complete sample :
pAddPar = &(*addPars)[3]; pAddPar->typeID = APIParT_RealNum; pAddPar->typeMod = API_ParArray; pAddPar->dim1 = 3; pAddPar->dim2 = 4; CHTruncate ("matrix", pAddPar->name, sizeof (pAddPar->name)); GS::ucscpy (pAddPar->uDescname, L("Array parameter with real numbers")); pAddPar->value.array = BMAllocateHandle (pAddPar->dim1 * pAddPar->dim2 * sizeof (double), ALLOCATE_CLEAR, 0); double** arrHdl = reinterpret_cast<double**>(pAddPar->value.array); for (Int32 k = 0; k < pAddPar->dim1; k++) for (Int32 j = 0; j < pAddPar->dim2; j++) (*arrHdl)[k * pAddPar->dim2 + j] = (k == j ? 1.1 : 0.0);
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2016-02-23 06:26 PM
2016-02-23
06:26 PM
Hey.
Thank you for the reply. I have looked at the LibPart_Test, but it was from the ArchiCAD 18 DevKit (the one I'm currently using) and it did not had the array example. I assume that the one you are using is the one from the ArchiCAD 19 DevKit.
I will try to get the one from the most recent DevKit, thank you.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2016-02-24 03:44 PM
2016-02-24
03:44 PM
Hey.
I have successfully created arrays of various types (such as APIParT_RealNum, APIParT_Integer ...) using the example you mentioned.
However, I have found another obstacle, I cannot seem to be able to create arrays of type string (APIParT_CString).
Anyone can help me with that?
I have tried to allocate space for char or double, and do the respective cast, but had no luck.
UPDATE:
I have found the solution:
Best regards,
Xylios
(*addPars).value.array = BMAllocateHandle(4 * sizeof(char), ALLOCATE_CLEAR, 0); char** arrHdl = reinterpret_cast<char**>((*addPars).value.array); //(*addPars).value.array = BMAllocateHandle(4 * sizeof(double), ALLOCATE_CLEAR, 0); //double** arrHdl = reinterpret_cast<double**>((*addPars).value.array); (*arrHdl)[0] = 'a'; (*arrHdl)[1] = '\0'; (*arrHdl)[2] = 'b'; (*arrHdl)[3] = '\0';
UPDATE:
//actualSize is the number of characters of every strings you want added plus the number of said strings //ex: you want two strings "abc" and "st", the value of actualSize will be 3 + 2 + 2 = 7 //to note that the dim1 will still be the number of strings you want, in this example, 2. But you will allocate space for every character plus every separator '\0'. //the final value of the array will be "abc\0st\0" int numberOfStrings = 2; (*addPars).dim1 = numberOfStrings; (*addPars).dim2 = 1 (*addPars).value.array = BMAllocateHandle(actualSize * (*addPars).dim2 * sizeof(GS::uchar_t), ALLOCATE_CLEAR, 0); GS::uchar_t** arrHdl = reinterpret_cast<GS::uchar_t**>((*addPars).value.array);Hope that this can help anyone with the same problem.
Best regards,
Xylios
