dushyant
Looping through GS::Array<API_Guid>
Hi
How can I loop through the items stored in a GS::Array<API_Guid> array? I want to print all the Guids stored in it, say via ACAPI_WriteReport()..
(Also, how do you normally print out data to check values while developing/debugging?)
I tried: for (int i = 0; i < sizeof(arrayName); i++) { .. } but it is giving out some strange results.
Thanks
7 Replies 7
Viktor Kovacs
You can use it like an std::vector.
For example:
for (UIndex i = 0; i < array.GetSize (); i++) {
    const API_Guid& guid = array;
    // do something with the guid
or
for (const API_Guid& guid : array) {
Hi, try:
GS::Array<API_Guid> array;
    for(auto element : elemList)
or
    for (GS::Array<API_Guid>::ConstIterator element = array.Enumerate(); element  != nullptr; ++element )
dushyant
Thanks Viktor and Konstantin.
I am trying to print the Guids using ACAPI_WriteReport() , as I don't know of any other way to print debug info in Archicad, using the "%s" format specifier, like this:
for (const API_Guid& guid : arrayOfGuids) {
      ACAPI_WriteReport("%s", false, guid);
It is not printing anything. How to print an API_Guid ?
Thanks
poco2013
Mentor
This will work but is not the optimum way. Someone else may input the proper utility but this is what I use.
char hold[254] = {};
APIGuid2GSGuid(guid).ConvertToString(hold)
ACAPI_WriteReport("%s",false,hold);
Gerry
dushyant
Code: Select all
Thanks Gerry, that worked perfectly.
So API-Guid and GS-Guid are different?
poco2013
Mentor
They are essentially the same thing except GS::Guid is packed as a Class and API_Guid is a structure.
From the API Manual:
"API_Guid is essentially a GS::Guid. It has the same size and structure, and only exists because of certain C++ language limitations: namely that a union (like API_Element) cannot contain a class which has a constructor or destructor. Since API_Elem_Head needs to contain a Guid member, and it cannot be a GS::Guid, the API_Guid structure was introduced."
Gerry
dushyant
Thanks a lot Gerry!
