Archicad C++ API
Matlab Engine from Add on
Hey,
I would like to call the Matlab Engine, but when I call
Engine *ep;
ep = engOpen(NULL);
then I succeed to compile, but the Add-on doesn't load anymore. (I use an example provided by Matlab) I have the required libs in the solution explorer, and windows.h and engine.h is in the header.
Any ideas what could be the problem?
Andor
Why are you passing NULL as a parameter? I think there would be a SIGSEGV and your addon crash immedialety, that is why it is not loaded.
Thanks for the reply, I solved it..
NULL is required by Matlab, it has a sample application. I had to set the PATH, so know everything loads.
