LeeJaeYoung
Re: How can I do it like fit to skin? sect_fill "insulation 01"
It seems that 3D Script does not support Fit to Skin of Building Material, is that correct?
Thanks for the reply.
AC27 on window 11
2 Replies 2
runxel
For textures you'd need to look into GDL primitives and TEVE.
However as far I am aware this has no effect on the internal engine, which also drives the section/elevation/3d doc generation.
So all in all: that's not possible.
LeeJaeYoung
I also need to have Sect Fill's Fill Orientation and a scale that can be adjusted to fit the thickness, but it doesn't seem to be in gdl yet.
Thank you so much for your reply.
AC27 on window 11
