2007-07-24 05:17 PM - last edited on 2023-08-04 08:53 PM by Doreena Deng
2007-07-24 05:23 PM
2007-07-24 05:26 PM
TomWaltz wrote:I do so, but I thought there was another more correct way
You're correct that it's not simple.
The most common approach I've seen is to place a roof at the angles creating your triangle, then use the Solid Element Operations tools to subtract the roof from the wall.
