[SOLVED] ACAPI_KeepInMemory problem
Hi
I have a dialog which inherits from DG::Palette class.
Here is my dialog's header class
class IssuesDialog : public DG::Palette, public DG::ButtonItemObserver, public DG::ListViewObserver
private:
	DG::LeftText			m_textViewGuid;
	DG::LeftText			m_textViewId;
	DG::TextEdit			m_textEditTitle;
	DG::TextEdit			m_textEditDesc;
	DG::PopUp				m_cbStatus;
	DG::Button				m_btnFindObject;
	DG::Button				m_btnSaveData;
	DG::SingleSelListView	m_listIssues;
	DG::Button				m_btnClose;
public:
	IssuesDialog();
	~IssuesDialog();
	void setInstance(IssuesDialog *instance);
private:
	bool	validate();
	void	fillListView();
protected:
	void	ButtonClicked (const DG::ButtonClickEvent& e);
	void	ListViewSelectionChanged ( const DG::ListViewSelectionEvent& ev);
private:
	IssuesDialog(const IssuesDialog&);
	const	IssuesDialog& operator=(const IssuesDialog&); //Disabled
private:
	IssuesDialog *current_dialog;
	IssueDataObject *issueDataObject;
And here is the code when I open the dialog from other .cpp file
IssuesDialog *issuesDialog = new IssuesDialog();
issuesDialog->setInstance(issuesDialog);
issuesDialog->Activate();
issuesDialog->BeginEventProcessing();
issuesDialog->BringToFront();
issuesDialog->Show();
ACAPI_KeepInMemory(true);
When I close the dialog I call the following code
SendCloseRequest();
this->current_dialog->EndEventProcessing();
delete this->current_dialog;
ACAPI_KeepInMemory(false);
Everything goes correct and dialod closes withouth any errors but when I want to change something in my add-on code and rebuild again I'm getting the following error
warning : Access to the path 'BuildingCloud.apx' is denied
error LNK1104: cannot open file 'BuildingCloud.apx'
I believe above error mean there is a something which not removed from memory.
By the way this error also appears in archicad add-on examples which provided in ApiDevKit Examples folder.
Is there a way to solve this issue ?
Thanks in advace.
6 Replies 6
Ralph Wessel
That's a build problem rather than a runtime error. Do you quit from ArchiCAD when you want to make changes and rebuild?
Ralph Wessel BArch
Central Innovation
No I don't quit ArchiCad when I do rebuild. When I don't use ACAPI_KeepInMemory without closing ArchiCad rebuild works fine . So it's related with ACAPI_KeepInMemory. I think something is not removed from memory.
Ralph Wessel
Yes, you're right in saying that something is not removed from memory; it's the add-on itself. The documentation states that the following about ACAPI_KeepInMemory:
Instructs the host application to keep the add-on in the memory
But when you rebuild, you are effectively attempting to unload and reload the add-on. Those actions aren't compatible, and I wouldn't do it even if no errors were reported. I highly recommend always quitting from ArchiCAD whenever you want to rebuild.
Ralph Wessel BArch
Central Innovation
Ok. But it's take time to close ArchiCad and open. We can pass false to ACAPI_KeepInMemory function but it doesn't work even in that case.
Ralph Wessel
You have to accept some unique constraints for plugin development. It isn't the same as developing a stand-alone application.
Ralph Wessel BArch
Central Innovation
Thanks for reply!
