[SOLVED] Panel_Test problems
Hi
I compiled the apx and loaded it through the Add-on Manager.
But I dont see any additional panels. Where are these panels visible?
My goal is to provide a custom UI for values I stored with ACAPI_Element_SetUserData().
On another note, just to verify that it cant be done. I have not found a API function which allows to add a parameter programmatically so that its visible in a library parts Custom Settings panel. Can you add parameters only through the GDL editor manually?
Thanks
Dimi
4 Replies 4
Ralph Wessel
christop wrote:
Hi
The example add-ons will only load if you run ArchiCAD as a demo, i.e. no active licence or keyplug. If you're running it licensed, you won't see anything. Also, check the Add-On Manager to see if the add-on is loaded.
The GDL UI can't be interactively modified by an add-on. It could modify the UI script, but I don't think that's what you want.
Ralph Wessel BArch
Central Innovation
Hi
thanks for the reply.
I dont have problems building and executing in ArchiCad many of the other add-ons.
The Panel_test example compiles and is loaded through the Add-ON manager without a problem. I just dont see the additional panels, where would they be displayed..... I was interested in creating custom panels in the settings dialogs.
Thanks
Dimi
Ralph Wessel
Do you need to show the panels in Work Environment > Tool Settings Dialog Boxes?
Ralph Wessel BArch
Central Innovation
Hi
this was it. You have to enable the visibility of the Panel from the ArchiCad Settigns.
I did need to enable the following settings.
Option->Work Environment->Tool Settings Dialog Boxes-> (Select wall)->(Enable panel Test Settings Pane by clicking on the grey eye icon)
Option->Work Environment->InfoBox-> (Select wall)->(Enable panel Test InfoBox Pane by clicking on the grey eye icon)
The Panel_Test Attribute Pane is visible through
Options->Element Attributes->Surfaces->(on the bottom)
Thanks
