[SOLVED] Crashing on SelectionChange Handler + Elem Observer
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2017-09-07
01:28 PM
2022-12-06
02:00 PM
Daniel Kassai
The crash happens when I do the following:
1) Open up the palette + Init handlers
2) Select an elem
3) Delete the selected elem
4) Select another elem
5) Undo-delete (Ctrl+Z). Archicad crashes immediately right after undo is pressed
Further testing:
1-3) Do actions
4) If I did not select an elem after deletion and went directly to undo-delete = no crash
Another scenario:
1-3) Do actions
4) If I multi-select elems after deletion then pressed undo = no crash
Another scenario:
1-4) Do actions
5) Un-select it, select another elem (repeated x times)
6) Undo-delete:
6a) If it has a selected elem = crash
6b) If it has no selected = no crash
Below is the code for the handlers, I've emptied the Elem Observer and palette (its created but no dialog items) so I know the SelectionChangeHandler has the problem.
API_Guid g_guidPrev = APINULLGuid; bool g_hasSelected = false; GSErrCode Observer_DetachAllElems() { API_Elem_Head** elemHead; Int32 nElems = 0; GSErrCode err = ACAPI_Element_GetObservedElements(&elemHead, &nElems); if (err != NoError) { WriteReport("["__FUNC__"] ERROR %s - ACAPI_Element_GetObservedElements", ErrId2Name(err)); return err; } for (Int32 i = 0; i < nElems; i++) { err = ACAPI_Element_DetachObserver(&(*elemHead)); if (err != NoError) WriteReport("["__FUNC__"] ERROR %s - ACAPI_Element_DetachObserver()", ErrId2Name(err)); } BMKillHandle((GSHandle*)&elemHead); return err; } GSErrCode Observer_AttachElem(API_Guid guid) { // Get element head API_Elem_Head head; BNZeroMemory(&head, sizeof(head)); head.guid = guid; GSErrCode err = ACAPI_Element_GetHeader(&head, APIElemMask_FloorPlan); if (err != NoError) { WriteReport("["__FUNC__"] ERROR %s - ACAPI_Element_GetHeader()", ErrId2Name(err)); return err; } // Attach elem to observer err = ACAPI_Element_AttachObserver(&head, NULL); if (err != NoError) WriteReport("["__FUNC__"] ERROR %s - ACAPI_Element_AttachObserver()", ErrId2Name(err)); return err; } static GSErrCode __ACENV_CALL ElemObserverEventHandler(const API_NotifyElementType* /*elemType*/) { // Empty function return NoError; } // ElemObserverEventHandler GSErrCode InitializeElemObserverHandler() { const GSErrCode err = ACAPI_Notify_InstallElementObserver(ElemObserverEventHandler); if (err != NoError) DBGPrintlnf("[Error] %s "__FUNC__" - ACAPI_Notify_InstallElementObserver(ElemObserverEventHandler)", ErrId2Name(err)); return err; } static GSErrCode __ACENV_CALL SelectionChangeHandler(const API_Neig *selElemNeig) { if (selElemNeig == nullptr) return NoError; if (selElemNeig->neigID == APINeig_None) { WriteReport("All elements deselected"); if (g_hasSelected) // Deselected (currently no selection & previously has selection) { g_hasSelected = false; // Detach previous elem Observer_DetachAllElems(); } return NoError; } API_Neig** selNeigs; API_SelectionInfo selectionInfo; BNZeroMemory(&selectionInfo, sizeof(selectionInfo)); GSErrCode err = ACAPI_Selection_Get(&selectionInfo, &selNeigs, true); BMKillHandle((GSHandle*)&selectionInfo.marquee.coords); if (err == APIERR_NOSEL) { WriteReport("["__FUNC__"] ERROR %s - ACAPI_Selection_Get()", ErrId2Name(err)); err = NoError; if (g_hasSelected) // Deselected (currently no selection & previously has selection) { g_hasSelected = false; // Detach previous elem Observer_DetachAllElems(); BMKillHandle((GSHandle*)&selNeigs); return err; } } if (err != NoError) { WriteReport("["__FUNC__"] ERROR %s - ACAPI_Selection_Get()", ErrId2Name(err)); BMKillHandle((GSHandle*)&selNeigs); return err; } if (selectionInfo.typeID != API_SelEmpty) { // collect indexes of selected dimensiosn const UInt32 nSel = BMGetHandleSize((GSHandle)selNeigs) / sizeof (API_Neig); if (nSel != 1) { // exit since invalid selection, accept only single select BMKillHandle((GSHandle*)&selNeigs); return err; } // Valid selection: single select API_Guid guid = (*selNeigs)[0].guid; BMKillHandle((GSHandle*)&selNeigs); if (g_guidPrev == guid) // Exit now if selected elem did not change return NoError; // Detach previous elem Observer_DetachAllElems(); g_guidPrev = guid; g_hasSelected = true; // Check if elem is already being observed API_Elem_Head** elemHead; Int32 nElems = 0; err = ACAPI_Element_GetObservedElements(&elemHead, &nElems); if (err != NoError) { WriteReport("["__FUNC__"] ERROR %s - ACAPI_Element_GetObservedElements", ErrId2Name(err)); return err; } for (Int32 i = 0; i < nElems; i++) { if ((*elemHead).guid == guid) // Exit if already observed { BMKillHandle((GSHandle*)&elemHead); return NoError; } } BMKillHandle((GSHandle*)&elemHead); // Attach elem to observer Observer_AttachElem(guid); } return NoError; } // SelectionChangeHandler GSErrCode InitializeSelectionChangeHandler() { const GSErrCode err = ACAPI_Notify_CatchSelectionChange(SelectionChangeHandler); if (err != NoError) DBGPrintlnf("[Error] %s "__FUNC__" - ACAPI_Notify_CatchSelectionChange(SelectionChangeHandler)", ErrId2Name(err)); return err; }
- Labels:
Add-On (C++)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2017-09-07 06:16 PM
Erenford wrote:Have you debugged into this code to determine where the crash occurs? That might yield valuable clues to the source of the problem.
Greetings, I'm having problems when using two Notification handlers. Basically it's a palette that uses SelectionChangeHandler to detect selected element (if wall is selected, it will show stuff) then ElemObserverHandler to detect changes from that element so the palette can update automatically. I attach elems to the observer in the SelectionChangeHandler function if it detects valid selection.
Central Innovation
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2017-09-08 05:33 AM
Ralph wrote:Yes I forgot to mention that. I've tried but the crash occurs even before entering the SelectionChangeHandler function. I inserted a debug print at the very start of the function, did the actions above, and it crashes before printing it, immediately right after pressing undo.
Also I've attached the BugReport dump maybe it may help. I've noticed that my addon isn't listed in the call stack, usually its there and I can pinpoint which part of my code it last ran.
This is in AC 20 6005 by the way.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2017-09-11 11:13 AM
Ok I did a workaround for this issue by removing the Elem Observer entirely. I noticed that SelectionChangeHandler gets called anyway at probably most user action so I figured I can check the elem change in there instead of a separate handler. I tested it and it seems to work fine.
I still don't know what the cause of the crashes though.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2017-09-11 11:17 AM
Erenford wrote:What was the element observer doing? It wasn't trying to work on a deleted element by any chance?
[WORKAROUND]
Central Innovation
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2017-09-12 04:41 AM
Ralph wrote:No I only used the
After I came upon the crashes I emptied the ElemObserverEventHandler to test if its the cause, but it still crashes.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2017-09-12 11:02 AM
Thank you your comment. Unfortunately this is an ArchiCAD bug which is already in our bug database. We will try to do the best to fix it and place into the next update.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2017-09-13 03:51 AM
Mihály wrote:Great thanks for the notification, I'll mark this as solved then.
Hello Erenford,
