‎2017-09-07
01:28 PM
‎2022-12-06
02:00 PM
Daniel Kassai
API_Guid g_guidPrev = APINULLGuid;
bool g_hasSelected = false;
GSErrCode Observer_DetachAllElems()
API_Elem_Head** elemHead;
Int32 nElems = 0;
GSErrCode err = ACAPI_Element_GetObservedElements(&elemHead, &nElems);
if (err != NoError)
WriteReport("["__FUNC__"] ERROR %s - ACAPI_Element_GetObservedElements", ErrId2Name(err));
return err;
for (Int32 i = 0; i < nElems; i++)
err = ACAPI_Element_DetachObserver(&(*elemHead));
if (err != NoError) WriteReport("["__FUNC__"] ERROR %s - ACAPI_Element_DetachObserver()", ErrId2Name(err));
BMKillHandle((GSHandle*)&elemHead);
return err;
GSErrCode Observer_AttachElem(API_Guid guid)
// Get element head
API_Elem_Head head;
BNZeroMemory(&head, sizeof(head));
head.guid = guid;
GSErrCode err = ACAPI_Element_GetHeader(&head, APIElemMask_FloorPlan);
if (err != NoError)
WriteReport("["__FUNC__"] ERROR %s - ACAPI_Element_GetHeader()", ErrId2Name(err));
return err;
// Attach elem to observer
err = ACAPI_Element_AttachObserver(&head, NULL);
if (err != NoError)
WriteReport("["__FUNC__"] ERROR %s - ACAPI_Element_AttachObserver()", ErrId2Name(err));
return err;
static GSErrCode __ACENV_CALL ElemObserverEventHandler(const API_NotifyElementType* /*elemType*/)
// Empty function
return NoError;
} // ElemObserverEventHandler
GSErrCode InitializeElemObserverHandler()
const GSErrCode err = ACAPI_Notify_InstallElementObserver(ElemObserverEventHandler);
if (err != NoError) DBGPrintlnf("[Error] %s "__FUNC__" - ACAPI_Notify_InstallElementObserver(ElemObserverEventHandler)", ErrId2Name(err));
return err;
static GSErrCode __ACENV_CALL SelectionChangeHandler(const API_Neig *selElemNeig)
if (selElemNeig == nullptr)
return NoError;
if (selElemNeig->neigID == APINeig_None)
WriteReport("All elements deselected");
if (g_hasSelected) // Deselected (currently no selection & previously has selection)
// Detach previous elem
Observer_DetachAllElems();
return NoError;
API_Neig** selNeigs;
API_SelectionInfo selectionInfo;
BNZeroMemory(&selectionInfo, sizeof(selectionInfo));
GSErrCode err = ACAPI_Selection_Get(&selectionInfo, &selNeigs, true);
BMKillHandle((GSHandle*)&selectionInfo.marquee.coords);
if (err == APIERR_NOSEL)
WriteReport("["__FUNC__"] ERROR %s - ACAPI_Selection_Get()", ErrId2Name(err));
err = NoError;
BMKillHandle((GSHandle*)&selNeigs);
return err;
if (err != NoError)
return err;
if (selectionInfo.typeID != API_SelEmpty)
// collect indexes of selected dimensiosn
const UInt32 nSel = BMGetHandleSize((GSHandle)selNeigs) / sizeof (API_Neig);
if (nSel != 1)
{ // exit since invalid selection, accept only single select
return err;
// Valid selection: single select
API_Guid guid = (*selNeigs)[0].guid;
if (g_guidPrev == guid) // Exit now if selected elem did not change
return NoError;
g_guidPrev = guid;
g_hasSelected = true;
// Check if elem is already being observed
Int32 nElems = 0;
if (err != NoError)
return err;
if ((*elemHead).guid == guid) // Exit if already observed
return NoError;
Observer_AttachElem(guid);
return NoError;
} // SelectionChangeHandler
GSErrCode InitializeSelectionChangeHandler()
const GSErrCode err = ACAPI_Notify_CatchSelectionChange(SelectionChangeHandler);
if (err != NoError) DBGPrintlnf("[Error] %s "__FUNC__" - ACAPI_Notify_CatchSelectionChange(SelectionChangeHandler)", ErrId2Name(err));
return err;
‎2017-09-07 06:16 PM
Erenford wrote:Have you debugged into this code to determine where the crash occurs? That might yield valuable clues to the source of the problem.
Greetings, I'm having problems when using two Notification handlers. Basically it's a palette that uses SelectionChangeHandler to detect selected element (if wall is selected, it will show stuff) then ElemObserverHandler to detect changes from that element so the palette can update automatically. I attach elems to the observer in the SelectionChangeHandler function if it detects valid selection.
‎2017-09-08 05:33 AM
Ralph wrote:Yes I forgot to mention that. I've tried but the crash occurs even before entering the SelectionChangeHandler function. I inserted a debug print at the very start of the function, did the actions above, and it crashes before printing it, immediately right after pressing undo.
‎2017-09-11 11:13 AM
‎2017-09-11 11:17 AM
Erenford wrote:What was the element observer doing? It wasn't trying to work on a deleted element by any chance?
[WORKAROUND]
Ok I did a workaround for this issue by removing the Elem Observer entirely. I noticed that SelectionChangeHandler gets called anyway at probably most user action so I figured I can check the elem change in there instead of a separate handler. I tested it and it seems to work fine.
I still don't know what the cause of the crashes though.
‎2017-09-12 04:41 AM
Ralph wrote:No I only used the
‎2017-09-12 11:02 AM
‎2017-09-13 03:51 AM
Mihály wrote:Great thanks for the notification, I'll mark this as solved then.
Hello Erenford,
Thank you your comment. Unfortunately this is an ArchiCAD bug which is already in our bug database. We will try to do the best to fix it and place into the next update.
