Archicad C++ API
[SOLVED] How to programmatically change Picture size
Hi
My goal is to change Picture sizes in my C++ code.
Here is my code
IO::Location locationToPic ("d:\\Pictures\\67-hero.jpg");
const void* dgPicture = GX::Image (locationToPic).ToDGPicture ();
DGSetItemImage (IID_SETTINGS, 400, DG::Picture (dgPicture));
After above code I want to change width and height of picture.
Tibor Lorantfy
Graphisoft Alumni
Graphisoft Alumni
I wrote you an example code to show how to resize the image or the Picture dialog item:
GX::Image myGXImage (locationToPic);
	// resize the picture
NewDisplay::NativeImage	tmpNativeImage = ResizeNativeImage (myGXImage.ToNativeImage (), 64 /* new width */);
myGXImage = GX::Image (tmpNativeImage);
	// get the size of the resized picture
UInt32 picWidth = myGXImage.GetWidth ();
UInt32 picHeight = myGXImage.GetHeight ();
	// get actual size of the dialog item
short left, top, right, bottom;
DGGetItemRect (IID_SETTINGS, 400, &left, &top, &right, &bottom);
	// change dialog item size to equal the picture size
short hGrow = (right - left) - picWidth;
short vGrow = (bottom - top) - picHeight;
DGGrowItem (IID_SETTINGS, 400, hGrow, vGrow);
	// set the picture
const void* dgPicture = myGXImage.ToDGPicture ();
// Helper function to resize image
NewDisplay::NativeImage ResizeNativeImage (const NewDisplay::NativeImage& image, Int32 newWidth)
	if (image == NULL)
		return image;
	float scale = newWidth / image.GetWidth ();
	Int32 newHeight = image.GetHeight () * scale;
	NewDisplay::NativeImage retVal (newWidth, newHeight, image);
	NewDisplay::NativeContext context = retVal.GetContext ();
	context.DrawImage (image, scale, scale, 0.0, 0.0, 0.0, false);
	retVal.ReleaseContext (context);
	return retVal;
Hope it helps
Regards,
Tibor
Thank you for the answer!
This is what I needed!
