Archicad C++ API
String into UniString?
How can I convert a string to UniString?
Thanks!
leilei
Hi, you can do this:
std::string sTest;
GS::UniString sToUnistr;
sToUnistr=GS::UniString(sTest.c_str());
leilei
std::string sTest;
leilei
Sometimes you need to set character types.When I read the file path through string, I need to do this when I convert to unistring.
std::string sTest;
sToUnistr=GS::UniString(sTest.c_str(),CC_SimpChinese);
I want to use Hangul.
std::string sTest;
sToUnistr=GS::UniString(sTest.c_str(),???????);
I find that
CC_Korean in CH.hpp
in API Development Kit 26.3000\Support\Modules\GSRoot
Thank you so much ^^
AC27 on window 11
