2026-07-22
03:41 PM
2026-07-22
09:58 PM
All the channels presented and explained in this section are found in the Surface parameter settings in ArchiCAD.
They can be accessed in Options > Element Attributes > Surfaces...
How can I retrieve the Cineware and Redshift by Maxon engine properties like Color, Fog, Glow, Grass, etc?
Operating system used: Windows 11 25H2
2026-07-29 08:39 AM
I've asked a developer about it.
Regards,
Tamás
a month ago
I've got the reply from the developer, see it below.
Regards,
Tamás
With general API you cannot access this data.
There might be a work around, using ModelerAPI, but this works with a generated model only, which can be good for example if you want to export the model into a 3D format.
Check the DumpMaterialRenderingSettings function of the ModelAccess_Test example add-on of the API DevKit (Examples\ModelAccess_Test\Src\ModelAccess_Test_Writer.cpp). This can print the C4D parameters stored for the material attributes like this:
Parameter 1 : C4D_VER_MAIN
type: numeric
value: 1.000000
Parameter 2 : C4D_VER_SUB
type: numeric
value: 8.000000
Parameter 3 : C4D_CHCOL_COLOR
type: numeric array
dims: 3x0
[1] value: 0.827451
[2] value: 0.784314
[3] value: 0.670588
Parameter 4 : C4D_CHCOL_MODEL
type: string
value: OrenNayar
Parameter 5 : C4D_CHCOL_DIFFUSELEVEL
type: numeric
value: 1.500000
Parameter 6 : C4D_CHCOL_ROUGHNESS
type: numeric
value: 0.000000
Parameter 7 : C4D_CHDIF_MIXSTRENGTH
type: numeric
value: 0.150000
Parameter 8 : C4D_CHLUM_BRIGHTNESS
type: numeric
value: 0.000000
Parameter 9 : C4D_CHTRA_BRIGHTNESS
type: numeric
value: 0.000000
Parameter 10 : C4D_CHTRA_REFRACTION
type: numeric
value: 1.450000
Parameter 11 : C4D_CHTRA_FRESNELREFLECTIVITY
type: numeric
value: 0.000000
...However the mapping between the parameter names and the names displayed on the Surface Settings panel is not available here, these are part of the Cinema Rendering plugin only.
