Archicad C++ API
Why Does DG::GetDialogFromId Return nullptr in ArchiCAD 27 C++ API?
nishida_jp
In the ArchiCAD 27 C++ API, the following function returns nullptr for some reason:
[cpp]
DG::Dialog *dlg = DG::GetDialogFromId(dialID);
How can I correctly obtain a pointer to the DG::Dialog class from dialID using this function?
1 REPLY 1
Hiromichi Shinkawa
Hi, The dialID should be valid, you may use if (!DGIsDialogOpen (diallD) {} to check at first.
I noticed there are some places in API Examples code which using the same command DG::GetDialogFromId (), you can check whether it works on your pc.
HTH.
