RAFD
cannot open source file "ADBAttributeIndex.hpp"
Need help about this errors
1 Solution
Hiromichi Shinkawa
You can check new document or refer Examples code to find the changes then modify your code and solve the error one by one for AC27. For example, API_PenType is not used in AC27, you can find Example code in Attribute_test.cpp
HTH
Go to post
12 Replies 12
RAFD
I'm trying to upgrade the add-on to AC27 but I got errors while building the add-on
Hiromichi Shinkawa
The file is in the following folder of API kit:
"\Support\Modules\CADInfrastructureBase\"
so please check whether you've added the path in your VS project settings.
HTH
RAFD
I added the path but instead of fixing it from 9, I got 89 new errors. But the previews errors are gone. Does this error have to do with the API devkit? Because in version 26 it works fine.
Hiromichi Shinkawa
Please try to add the path into your VS project Include Directory like below:
RAFD
Got it. But new errors appears
Hiromichi Shinkawa
From AC27, many of function names has been changed, so you need to modify your code. here is a header file for your reference. You can also check the API27 documentation about the changes.
RAFD
Can you tell me more about this "ACAPI_MigrationHeader.zip"? How will I know the correct name to use?
Hiromichi Shinkawa
You can search the keyword then find the new name in this header file. for example,
APIDb_GetCurrentDatabaseID
the new function will be
ACAPI_Database_GetCurrentDatabase()
or try to include this header file into your old C++ file, but I don't want to suggest this way.
HTH
RAFD
I tried including the ACAPI_MigrationHeader.hpp and now all my errors are in that file
