RAFD
cannot open source file "ADBAttributeIndex.hpp"
Need help about this errors
12 Replies 12
Hiromichi Shinkawa
You can check new document or refer Examples code to find the changes then modify your code and solve the error one by one for AC27. For example, API_PenType is not used in AC27, you can find Example code in Attribute_test.cpp
HTH
RAFD
Got down to this last error. I tried to erased Win because there's no Win folder after Lib but after that I got 600+ errors
Hiromichi Shinkawa
The ACAPI_STATD.lib is not in WIN folder in API27 Dev. kit, please remove the WIN\ in VS project.
HTH
