2005-02-16 05:53 AM - last edited on 2022-12-13 10:34 PM by Daniel Kassai
2005-02-16 07:34 PM
Ferenc wrote:I can not help actually. I feel that reasons of both are simple, but it is hard to assume something certain.
Any ideas anybody?
(and I thought it will be a "simple" recompile.... (:
2005-02-16 07:54 PM
2005-02-16 08:12 PM
Ferenc wrote:I didnot find it anywhere. It was just just idea after i tried to reproduce the error. I have defined MSC_VER and then this errors arised.
That also would be an easy fix, maybe it should be mentioned somewhere in the dev doc. Where did you find it?
2005-02-16 08:41 PM
2005-02-16 09:07 PM
Ferenc wrote:Try before a small experiment to check MSC_VER value.
So which file should it be in (rc2?), to edit it manually?
2005-02-16 11:18 PM
2005-02-17 07:06 AM
Ferenc wrote:Then the idea on MS_VER was false and it is not that reason.
Well,
fatal error C1189: #error: "valid"
2005-02-17 02:35 PM
2005-02-17 06:21 PM
