Zhang
publish a plugin
I would like to ask how to release a plugin using the demo version of Archicad.Can this version of the packaged apx file be used by other machines?
5 Replies 5
Miha Nahtigal
It should work if you use a correct developer id and plugin id in your plugin's headers/resources.
BIMquants - Free Plugin for Quantities and Costs Estimation in Archicad | BIMrender - Free & Open Source Plugin for AI rendering in Archicad
Zhang
Does it only work on the full version of Archicad,and does the running machine need to be networked?
akomporday
Graphisoft Alumni
Graphisoft Alumni
Hi Zhang,
It will work with the full version of Archicad, and if you don't use network functionalities in your AddOn, then it won't need any network connection.
Zhang
Then I want to know how my developer ID and plugin ID work. Can you give me an answer, thanks
Zhang
The trial version of Archicad doesn't work with the apx plugin I provided, right?
