‎2023-12-20
07:46 AM
‎2024-09-17
12:50 PM
Doreena Deng
Hey,
I'm relatively new to the mac environment and I was trying to build an api addon via xcode.
I keep getting 'invalid resource compiler'. here is the actual logs
PhaseScriptExecution Generate\ ResourceObjects/AddOnResources.stamp /Volumes/AC_Addon/build/AC_Addon.build/Debug/Script-957E13CB870051DAB542C474.sh (in target 'AC_Addon' from project 'AC_Addon')
cd /Volumes/archicad-addon-cmake
/bin/sh -c /Volumes/AC_Addon/build/AC_Addon.build/Debug/Script-957E13CB870051DAB542C474.shTraceback (most recent call last):
File "/Volumes/archicad-addon-cmake/Tools/CompileResources.py", line 203, in <module>
sys.exit (Main (sys.argv))
File "/Volumes/archicad-addon-cmake/Tools/CompileResources.py", line 195, in Main
assert resourceCompiler.IsValid (), 'Invalid resource compiler'
AssertionError: Invalid resource compiler
Command PhaseScriptExecution failed with a nonzero exit code
Do i need to install gcc or g++ for this?
I know i definately have clang-13. here's clang -v command on the terminal. Do I need to update clang?
Apple clang version 13.1.6 (clang-1316.0.21.2.5)
Target: x86_64-apple-darwin21.6.0
Thread model: posix
InstalledDir: .../XcodeDefault.xctoolchain/usr/bin
It's worth mentioning i'm on MacOS Monterey 12.7
