2022-03-27
10:48 PM
2023-05-23
04:32 PM
Rubia Torres
Is there a way to define the ID of 3D elements (walls, slabs etc.) with some of its own properties .
eg. Wall = [Composite Name] + [Fire Rating] + [STC].
All of these have been defined, so would like a way to automate this rather than selecting all walls and changing manually.
Have tried the Element ID Manager but seems to only work to increment walls individually/or part of group and doesn't seem able to dynamically create IDs.
Thanks
Solved! Go to Solution.
2022-03-29 01:48 AM
I make a short Demo video to show a Python script to accomplish this.
Convert Element ID to new title based on three properties of the element
Attach is the script. Leave a comment if you have further questions.
2022-03-27 11:24 PM
AFAIK - This is not possible with the "built in"tools in Archicad. You could create a new property using a expression which would create the new Id, but you could not overwrite the "element ID" property which I believe is your intent.
There are a few alternatives.
You could export a schedule to excel. Create a macro there to overwrite the Element ID field then re import into Archicad.
You could create a C++ AddOn to directly overwrite the "element ID"
Or the easiest, most straight forward way would be to create and use a Python script. The script would involve only a few lines of code and would offer the most control over the logic, filtering and formatting.
2022-03-28 02:18 AM
I would like to know how this python script would be written. I am also interested in writing specific information to the elementID field.
2022-03-28 05:00 AM - edited 2022-03-28 05:00 AM
Does the element id manager not do what you are after?
2022-03-29 01:48 AM
2022-12-08 05:51 AM
Hello Gerry, many thanks for your very useful example.
Here I attach a variant avoiding the extra modules. Also there was a missing property (we are on the German AC) causing error.
This might be useful to others.
2022-12-11 03:01 AM
The video is set to private, I'd love to see it.
2022-12-11 03:27 AM
Try it now?
2022-12-11 03:35 AM
Thanks. It works now.
2025-07-30 03:16 PM
Hello is this still possible ? I'm starting with this Python API, but i'm unable to see the video :(.
