Patrick Sherwood
Dynamic ID Coding of Building Elements
Is there a way to define the ID of 3D elements (walls, slabs etc.) with some of its own properties .
eg. Wall = [Composite Name] + [Fire Rating] + [STC].
All of these have been defined, so would like a way to automate this rather than selecting all walls and changing manually.
Have tried the Element ID Manager but seems to only work to increment walls individually/or part of group and doesn't seem able to dynamically create IDs.
Thanks
1 Solution
poco2013
Mentor
I make a short Demo video to show a Python script to accomplish this.
Convert Element ID to new title based on three properties of the element
Attach is the script. Leave a comment if you have further questions.
Gerry
Go to post
9 Replies 9
poco2013
Mentor
AFAIK - This is not possible with the "built in"tools in Archicad. You could create a new property using a expression which would create the new Id, but you could not overwrite the "element ID" property which I believe is your intent.
There are a few alternatives.
You could export a schedule to excel. Create a macro there to overwrite the Element ID field then re import into Archicad.
You could create a C++ AddOn to directly overwrite the "element ID"
Or the easiest, most straight forward way would be to create and use  a Python script. The script would involve only a few lines of code and would offer the most control over the logic, filtering and formatting.
Gerry
I would like to know how this python script would be written.  I am also interested in writing specific information to the elementID field.
Kind Regards,
Sebastian Monroe
Director/Architect
T: +61 3 9017 6666
www.codearchitecture.com.au
NOM ARCH VIC ARB: 17939
Archicad v26, Mac Mini INTEL 64GB, AMD Radeon Pro
Does the element id manager not do what you are after?
poco2013
Mentor
Gerry
_c_
Hello Gerry, many thanks for your very useful example.
Here I attach a variant avoiding the extra modules. Also there was a missing property (we are on the German AC) causing error.
This might be useful to others.
_c_ | Archicad, Revit und Vectorworks stets in den letzten 2-3 Versionen | Mac 14, Win Pro 11
The video is set to private, I'd love to see it.
Jared Banks, AIA
Shoegnome Architects
poco2013
Mentor
Try it now?
Gerry
Thanks. It works now.
Jared Banks, AIA
MERLO
Hello is this still possible ? I'm starting with this Python API, but i'm unable to see the video :(.
Paulo Mendes Architect @ MERLO Architecture
MERLO Website
Intel I9 13900K + NVIDIA 4090 RTX for Archicad 28
