Archicad Python API
About automating tasks in Archicad using the Python API.
call an add-on from a python script
billatarcat
Does anyone have an example python script that calls / runs an add-on?
poco2013
Mentor
The Python API has no ability to call and run a C++ AddOn.
A Python script cam only communicate with a AddOn through a builtin function called -- ExecuteAddOnCommand - by passing certain parameters. However the AddOn must have pre-programmed and registered a class  to received the request. That class inherits from the AddOnCommand class.
An example of the Python function can be found on the Archicad PyPi site.
Archicad PyPi
A typical example of the required C++ API class could be found on Tibor's old example site on GitHub.
GitHub
Gerry
Hi Gerry,  TY for the speedy response!  I will check out the links you provide.  Very helpful!
