BIMx
About BIMx (mobile, web and desktop), connection to BIMcloud, and related technical questions.
BIMx Beginner
Try to export a BIMx model on Mac OS 10.8.5 with ArchiCad 17 using a trial version and this is what i get on the pull down menu.
Even if try from the 3D window BIMx is not available in the File/Save As options either.
Is this a Trial Version limitation or am i doing something wrong on the ArchiCad settings ?
1 REPLY 1
You must view your model in 3D then 'Save As' and also change the file type to 'BIMx'.
