We value your input!
BIMx
About BIMx (mobile, web and desktop), connection to BIMcloud, and related technical questions.
BIMx Viewer: Eye Height when "walking"
Stress Co_
Is there a way to set the camera height in "walk" mode, when using BIMx viewer on an IOS device?
The scale figure in the screen shot is about 5'-9" (172.7cm).
Feels like the camera is locked in "child's view" mode.
Marc Corney, Architect
Red Canoe Architecture, P. A.
6 REPLIES 6
Erwin Edel
I know you can set it up on the desktop viewer/editor. I don't know if it 'sticks' to the iOS viewer afterwards.
Or maybe it is a hidden tribute to Zoolander?
https://youtu.be/NQ-8IuUkJJc
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
Stress Co_
Yes, I need to make it at least 3 times bigger than this.
I tried saving a couple of new BIMx models (with the correct height set in the desktop viewer) and they all revert to a diminutive stature on the iPad.
Anyone know if the Pro (paid version) has the functionality to adjust camera ht.?
Erwin Edel
I think it just uses a completely different engine under the hood. Other than opening the BIMx file, there is very little common ground between the mobile and dekstop apps.
From our tall dutch perspective it is even worse
And it is a reverse zoolander, just scale your model down 3 times for it to look good in BIMx mobile
www.leloup.nl
Windows 10 Pro
As mentioned above i know you can open a bimx on desktop and re-save it after adjusting the head height (or other parameters such as lighting etc), i know that this saved file displays correctly once opened again on a desktop
not sure about mobile devices
If the Bimx doesnt retain the information saved into it, how are we supposed to give our files to our clients and expect them to view our files as they were intended?
there really needs to be more control on previewing the bimx on desktop and direct compatibility and uniform functionality between different devices.
I.e. why cant i view hyper models on a pc? only on mobile device?
Stress Co_
Height can be adjusted in the device settings.
bimx-application-settings-on-mobile-devices
Not perfect. Given a choice of:
- Lower
- Low
- Default
- High
- Higher
No way of knowing the elevation of these choices or how to set the default.
Stress wrote:
No way of knowing the elevation of these choices or how to set the default. :roll:
It seems the value of "Default" is hardcoded into BIMx application on iPad and is unrelated to the export camera height (even though you start at your camera height in flight mode, but you immediately drop down to "Default" as soon as you activate virtual joystick).
If we want to know exact values, we can, potentially, make a vertically graduated ruler object in AC, export it to BIMx and walk right to it on iPad. Changing the height setting in iPad Settings will show you what hardcoded "High" "Higher" "Low" "Lower" values are.
They come out to be 1,2m 1,4m 1,6m 1,8m and 2,0m respectively.
With 1,6m height being the "Default".
