Emre Senoglu
BIMx offline publishing in AC24
I've just noticed that the offline publishing for bimx files (through publisher sets) have been removed in AC24. Can someone confirm this, or is it just moved elsewhere?
AC27 ARM // MBP M2 Max // Twinmotion | Corona | Rhino
senoglu.co | archimats.com
6 Replies 6
I am not quite sure what you mean by 'offline' publishing, but you can still choose to publish a BIMx model from the FILE menu.
This will allow you to create a new publisher set or update an existing one.
If you don't have that option, then you may have to add it to your custom Work Environment or load a standard WE.
Emre Senoglu
This option is now gone.
It is still there for me.
Emre Senoglu
Interesting. I'm on demo, so that may be why. Just to confirm, you can still publish a file locally to your computer?
Yes, the option to publish it to a path located on your PC (or LAN, or BImcloud) is there.
The DEMO version does not allow saving, that is probably the reason you do not even see these options.
Emre Senoglu
fantastic, many thanks and apologies for the assumptions!
