BIMx
About BIMx (mobile, web and desktop), connection to BIMcloud, and related technical questions.
BIMx opening view
Tom Krowka
Have tried to save a hypermodel with photorender window as the opening view.   I can generate the render but I get an error when attempting to save to the BIMx site.    Do I have to use 3D window for the opening view for the BIMx to save?   It's not great quality.
Thanks Tom
Tom Krowka Architect
Windows 11, AC Version 26
Thomas@wkarchwk.com
www.walshkrowka.com
6 REPLIES 6
David Maudlin
Tom:
Have you pasted the photorender into the Project Preview window? This is how I create the BIMx opening image.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
AC29 USA Perpetual • Mac mini M4 Pro OSX15 | 64 gb ram • MacBook Pro M3 Pro | 36 gb ram OSX14
Thanks Dave, that does answer the question but here's the real question behind the question.    Can I create the whole BIMx hypermodel entity in the photorender window instead of the 3D window.   The model quality would be so much better when the client opens the hypermodel via the opening view.
Thanks Tom
Thomas@wkarchwk.com
www.walshkrowka.com
Tom:
I may not be following you now. The BIMx walkthrough model is generated separately, not from the 3D or photo render windows. In earlier versions of AC there was a check box in the Publisher for rendering the model at higher quality (and more time), but that was removed when BIMx was upgraded recently.
David
Hi Dave:   That does answer my question.   Basically am complaining about the walkthrough model quality.   Was trying to find a way to improve it.   Was under the assumption that the opening view had something to do with the quality of the walkthrough but apparently it does not.   So I guess I have to live with the black box of walkthrough model generation.
TK.
Thomas@wkarchwk.com
www.walshkrowka.com
OtisAlbert
@Tom Krowka wrote:
Have tried to save a hypermodel with photorender window as a opening view.   I can generate the render but I get an error when attempting to save to the BIMx site.    Do I have to use 3D window for the opening view for the BIMx to save?   It's not great quality.
Thanks Tom
My desire is to set a high-quality PhotoRendering view as the opening view for my BIMx model. However, when attempting to save to the BIMx site, I encountered an error. It seems like the BIMx export process prefers the 3D window for the opening view, but the quality isn't up to par. Has anyone successfully managed to save a PhotoRendering window view as the opening view in BIMx?
OtisAlbert:
This is my method:
1. Render the image in Cineware, 940x480 pixels.
2. Copy this rendering to the Project Preview window.
3. Save the ArchiCAD file.
4. Create the BIMx file.
5. Upload the BIMx file to the BIMX Transfer Model site.
An example is here: Master Suite Addition - Washington, DC
David
