BIMx
About BIMx (mobile, web and desktop), connection to BIMcloud, and related technical questions.
BIMx on website, inverted controls ?
Andre_Steynberg
Hi all
we're testing out the BimX Model transfer site to embed BimX models into our company website, which seems to be working fine.
BUT, for some reason the mouse controls are inverted on the website / online version, which makes navigation very frustrating.
Is there somewhere to switch of the inverted controls, I see no option in the BimX app?
Andre Steynberg
Win 10 64-bit
AC27
This is the info I got from GRAPHISOFT developers:
In BIMx Desktop Viewer it is possible to invert the Mouse direction with the "Mouse Invert" setting.
However, in the BIMx Web Viewer there is no such setting at the moment.
If you set the "Mouse Invert" setting to "YES" in the BIMx Desktop Viewer then the directions will be the same in the Desktop Viewer and the Web Viewer.
Development will consider adding this setting to later versions of the BIMx Web Viewer.
Andre_Steynberg
Awesome thanks Laszlo this works a treat
Andre Steynberg
Win 10 64-bit
AC27
