Can't Publish to BIM
Cant publish my pln to BIM "publish to bimx" is not availabe cant be clicked
9 Replies 9
David Maudlin
isabelacruz:
If you are referring to BIMX, it can be saved from the 3D Window, not the plan.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
in 3d window but still can't publish to BIM
i am using archicad 18 64-bit
You can "Save As" and choose the BIMx option for a model you can move around, but for the BIMx Hyper-models (with links and 2D / 3D navigation) you need to purchase the BIMx Pro license.
s2art wrote:
...but for the BIMx Hyper-models (with links and 2D / 3D navigation) you need to purchase the BIMx Pro license.
Anyone should be able to publish a BIMx Hyper-model.
You just need to purchase a license to view it on your mobile device.
Check your Add-on Manager (Options menu) to see if the BIMx add-on is installed.
It should be as it comes default with Archicad (from version 17).
If it isn't active all I can think of is to repair or re-install Archicad.
There will be other posts here about BIMx not being available - it is just a matter of finding them.
i checked the add-on manager
how can i fix this: says error loading in bimx add-on
p.s: downloaded my archicad on torrent
So you don't have a WIBU or Codemeter license?
That would be why it doesn't work.
You must have a valid license for it to work.
do i have to uninstall and reinstall it again
Not if you don't have a proper (paid for) license from your local distributor.
It will make no difference - BIMx just won't work without it as far as I know.
