Stavadi
Can't publish to PDF and DWG anymore
I have a little problem (hopefully).
I worked in a archicad model, and wanted to add a sketchup model into it.
So I used the function to merge.
Afterwards the model was change to a BIMx file, and I can't select the option to publish to pdf or dwg...
Anybody knows how to reverse this?
Thanks in advance.
With kind regards,
Stan van Dijck
1 Reply 1
So, where is the ARCHICAD model that you saved the BIMx file from?
