2016-04-09
06:40 PM
2023-05-09
03:04 PM
Noemi Balogh
2016-04-09 07:26 PM
2016-04-10 01:53 AM
ejrolon wrote:Thank you for your response but when I go to my file drop down menu the 'BIMx HyperModel' is greyed out.
You don't save to BIMx, you Publish.
File->Publish BIMx HyperModel
2016-04-10 02:07 AM
2016-04-10 05:55 AM
2016-04-10 03:26 PM
ejrolon wrote:Yes.
Are you doing it from the 3D Window?
2016-04-10 03:27 PM
Barry wrote:Hi
BIMx is an add-on that is installed with Archicad (since version 17).
Check you Add-on Manager to see if it is or isn't installed correctly (I am guessing it is not).
See this post ...http://archicad-talk.graphisoft.com/viewtopic.php?p=253875
If it isn't then you can try installing the latest hotfix (upgrade) for Archicad - you don't say what version you are using.
If that doesn't work then the only other solution seems to be un-install Archicad and then re-install it.
http://archicad-talk.graphisoft.com/viewtopic.php?t=52161
http://archicad-talk.graphisoft.com/viewtopic.php?t=49220
2016-04-11 02:47 AM
Rich_B wrote:'Options' menu.
Forgive my ignorance but where is the Add-On Manager?
2018-06-13 09:53 AM
2018-06-13 10:44 AM
