How to delete BIMx models from your iOS device
When your iPhone or iPad device is filled up with BIMx models you might want to clean up a bit by erasing the old, unused ones. You have two options to delete models from your BIMx app:
Method 1 - Use swipe-delete in BIMx
In the Models List swipe to the left with your finger on the model you want to erase, then tap on the appearing Delete button:
Method 2 - Erase models with iTunes
Alternatively you can delete models with your laptop/desktop machine via iTunes:
  1. Connect the iOS device to the machine with a cable.
  2. In iTunes click on the appearing button with the device’s name.
  3. Choose the Apps tab and scroll down to File Sharing.
  4. Select BIMx from the list.
  5. Select the model you want to erase and hit Backspace (on Mac) or Delete (on Windows).
  6. Click Delete button on the appearing pop-up.
