We value your input!
BIMx
About BIMx (mobile, web and desktop), connection to BIMcloud, and related technical questions.
Possible to export BIMX as a white model?
paulmckean
Hi. Looking to export a BIMX model as a white model. Possible? Thanks.
Archicad 20, windows.
4 REPLIES 4
Post moved.
Please read the section descriptions to determine where best to post.
Thanks.
just out of curiosity? where was the thread moved to?
i searched the categories front pages and couldnt see it anywhere?
and with no other obvious place to ask questions about bimx other than 'working in archicad' i cant see where it would have gone otherwise
Eduardo Rolon
Here
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
another Moderator
ah of course i read this after the move makes sense now,
paulmckean if you want to export a bimx as a white model you could try using the graphic overrides if you are using v20.
this can make all materials white, doing it this way would mean your client also wouldn't have to go changing any settings within the bimx viewer program itself and you can do this using the Global Illumination engine turned on
(as normally you are unable to save a bimx after altering the view cone, eye height,or scene rendering like you once could in older versions of the bimx viewer)
