2020-01-09
10:34 PM
2025-03-26
04:02 PM
Gordana Radonic
2024-01-29 09:33 AM
Hi @karsonardo,
Sorry to hear you're experiencing an issue.
Could you please send the problematic project in PLA format to bimx@graphisoft.com so we can investigate this issue?
Kind regards,
Oleksandra Vakariuk
Technical Support Engineer2024-04-26 09:04 AM
Great!! This so simple yet I didn't think of it.
thanks 😄
2024-11-23 04:17 AM
I'm having this issue too, has anyone figured out the fix?
Thanks
2024-11-24 02:45 AM
Have you tried all of the suggestions mentioned previously in this post?
Is please post a screen shot of the publishing dialogue as in the first post (showing the entire file name).
Barry
2026-04-21 01:04 AM
I am having the same issue when trying to publish to .dwg from the Publisher. Error message: "Publishing of the item failed because Archicad was unable to generate it." I have tried all of the suggestions mentioned previously in the post.
Also cannot "Save As" to .dwg or .dxf. I get the message, "Cannot write output file". I get this message from any view I use, particularly story windows, or worksheets. I get the same error whether I select "Marquee area" or "Entire drawing" when asked "Which elements do you want to save?"
I am working in AC 29.1.0 (4006) USA FULL. I am working on the file in Teamwork, but I have tried saving to a .pln on my desktop, still the same issues as above. I have restarted ArchiCAD, and my computer.
Does this sound like an error with the file? It is an embarassingly large file size.
