Virtual Building Explorer for Mac??
Hello
Anyone knows when the mac version of VBE will be released?
7 Replies 7
Today:
http://archicad-talk.graphisoft.com/viewtopic.php?t=29913
Finally, Thanks.
I have tried unsuccessfully to install this on several macs. I get the same error during installation each time:
Warning!
No ArchiCAD 13 components found at location
Macintosh HD:Applications:Graphisoft:ArchiCAD 13.
Please click the Back button and select another ArchiCAD 13 folder.
Of course, the standard ArchiCAD installation exists here. This happened at work and at my machine at home. I have tried to download a couple times as well.
Rafal SLEK
I got no problem with installation - VBE2.0 INT version on AC13 INT - MacOS 10.6 Polish.
Best
Rafał
//Archicad since 4.1 version
//MacBook Pro Tahoe/Retina 2019/2.4 GHz/Intel Core i9/32GB RAM/Radeon Pro 5500M 4GB/
//MSI AMD Ryzen AI 9/2.5GHz/32GB/Nvidia RTX 5070 Ti/Windows 11 Pro
//ArchiCAD Collaborate
No problems installing on SL with 13.
Daniel, Is there any chance that you renamed the ArchiCAD.app or in some other way changed the content of your AC 13 folder? Maybe repair permissions if that's not it?
Thanks Karl,
That was it. Application was renamed ArchiCAD 13. Changing the name back allows the installer to work.
Chazz
Same issue for me (and probably lots of other folks). I noted it elsewhere.
Nattering nabob of negativism
