‎2011-06-09
11:07 AM
‎2023-05-09
01:15 PM
Noemi Balogh
‎2011-06-11 02:47 AM
‎2011-06-15 03:55 PM
‎2011-06-28 08:16 PM
‎2011-06-29 12:58 PM
‎2011-06-30 01:58 PM
‎2011-08-05 04:47 PM
Emre wrote:I would love some tips.
Try experimenting with bake object. Its fairly easy. C4D also allows you to bake groups, so instead of baking each wall and object, you can just pick the walls group imported from the archicad model and bake all the wall textures into a single file (well 2 files, one for tex. one for lum.) Note that you have to check the right options in bake object dialog to get the GI and the AO settings correctly.
If you still cant manage to get it done, I'll try sending you screenshots of the process😉
‎2011-08-15 01:16 PM
‎2011-08-17 10:46 AM
mattb wrote:Blender (http://www.blender.org) is Open Source and can load 3ds files (e.g. from ArchiCAD 3D Window) and export them into DAE.
Does anyone have a cost effective way of converting AC files to DAE? Or to sketchup 7 without paying for pro version?
Cheers
Matt
‎2011-08-31 11:12 PM
Alex wrote:Hi Alex, we have something in the works that will hopefully solve this problem for you. but can't say much at this stage....
I love the idea of VBE creating stand-alone walk-through models and would like to look at possibilities of embedding these into web pages. Unfortunately *.exe is a very "unfriendly" web format
Does anyone know if its possible to produce or convert VBE files to Flash or Similar formats. Otherwise, is anyone aware of any other ArchiCAD plug-ins that can achieve this?
