2007-11-08 01:07 AM - last edited on 2023-05-09 01:02 PM by Noemi Balogh
2009-03-31 08:44 PM
"cutimbo" wrote::?:
Ok
bug VBE librerias
2009-04-01 02:31 AM
Wokka wrote:Carstene wrote:Carsten,
Hi
I have attached an AC 12 .gsm library file. It's just a stair done in AC 11, saved from AC 12 as .gsm. Just wondering if anybody could place this in a empty AC 12 file and get it into VBE and check if there are any problems, thanks.
Carsten
Looks fine. No problems.
2009-04-01 03:01 AM
2009-04-01 04:01 AM
Wokka wrote:Wokka, great thanks.
32 Bit, VBE12-INT
Trial 1.0.6690
Cheers
2009-04-01 03:28 PM
2009-04-01 04:14 PM
cutimbo wrote:Is it possible that your original model is not located close to the true user origin? Models located many km away from the user origin will display strangely even in ArchiCAD.
well it seems that the error is not visible in the VBE trial version and tried to change the parameters of the libraries and in some cases it works, but it is not possible, but not all libraries are the same.
2009-04-07 06:53 AM
Karl wrote:Hi Karl, here you go, the ZIP file. Yes only the stair which is not far away from the origin. But I know what you mean, if it is to far away from the origin some software have problems to display it correctly even 3D Studio MAX get's to a point where it can't handle it anymore.cutimbo wrote:Is it possible that your original model is not located close to the true user origin? Models located many km away from the user origin will display strangely even in ArchiCAD.
Edit: Oh, I see we're talking about just the stairs that you posted. Please post as a zip. I refuse to install any software that unpacks rar on principal.
2009-04-07 06:58 AM
Karl wrote:Which principle is that?
I refuse to install any software that unpacks rar on principal.Karl
2009-04-07 07:28 PM
Erika wrote:...that rar is not a format that should be used on public forums such as this, but rather for personal or specialized needs, since the software to open rar files is not built into either Windows or Mac OS as is the case with zip. If feel the same way about (stuffit) SIT files.Karl wrote:Which principle is that?
2009-04-07 07:30 PM
Carstene wrote:Thanks. Will take a look and post back if I see anything new...
