please.. I have Proplem in Bimx> :(
Please Iam arabi man
Iam 20 years old
I Cant speak English good
But I try that ..
I want help for my problem in Bimx for ARCHICAD 18 >
my problem is ...I cant found" export the model from BIMx in any format"
what can I do Now?!Bimx
NOTE: I have application on my computer
10 Replies 10
Dave Seabury
Zeeyado
You Publish (through the navigator) to Bimx, Not save as.
AC 19-26 Windows 10 64 bit, Dell Prercision 7820, Xeon Silver 2414R ( 12 Cores), 64 GB Ram, Quadro RTX 4000 8GB
TMA_80
the easiest way:
File > Publish BIMx Hyper-Model
You could also see the other options here
AC12_27 |Win11_64bit|
TMA_80 wrote:
the easiest way:
Dave wrote:
Zeeyado
THANKS Alot .....my friends
but. sorry ..
I want to say something
I've been working in ARCHICAD 17
When I want to save the project to the BIMX .. follow these steps:
1. open a 3D window
2- file>save as>select ".bimx" format
3- finally ! click on save button .....
NOW !
I followed your method ....
but I have new problem
you can see it in the image
thanks agin !
Check your Add-on manager (in the Options menu).
Sounds like your add-on is not installed.
As far as I know it is not a separate add-on that you can install yourself.
It is automatically installed when you install Archicad.
All I can suggest is to re-install Archicad.
But maybe wait a bit to see if anyone else here has other suggestions.
THANKS for your suggest...
my dear .. I check about my add-ons in "Add-on manager"
and I found this problem next BIMx add-on.. in the image
NOW !
Iam re-install BIMx add-on
or / re- install ARCHICAD.
THANKS ALL ..FOR YOUR HELP .. I STILL WAIT FOR HELP
I found another post where someone had the same problem.
It seems re-installing Archicad fixed it for them.
http://archicad-talk.graphisoft.com/viewtopic.php?t=49220
OK!
I will try that now ....
thanks my dear.
but . I have question about this commond ...
can I export my project from this commond to
BIMx for (desktop - ipad - iphone....more) or no !
Yes once installed successfully you can save for all devices.
You will have the 'Save as ... BIMx' option from the 3D window which is good for desktop and mobile devices and you will be able to 'Publish' a hyper-doc which can be viewed on mobile devices.
thanks very much ...
thanks for help
I will re-install archicad 18 , after that I put my post here .
