2016-03-23 07:51 PM - last edited on 2023-05-09 03:47 PM by Noemi Balogh
2016-03-23 08:12 PM
2016-03-23 08:25 PM
2016-03-24 04:54 AM
TMA_80 wrote:
the easiest way:
File > Publish BIMx Hyper-Model
You could also see the other options here
Dave wrote:THANKS Alot .....my friends
Zeeyado
You Publish (through the navigator) to Bimx, Not save as.
David
2016-03-24 05:11 AM
2016-03-24 07:25 AM
Barry wrote:
Check your Add-on manager (in the Options menu).
Sounds like your add-on is not installed.
As far as I know it is not a separate add-on that you can install yourself.
It is automatically installed when you install Archicad.
All I can suggest is to re-install Archicad.
But maybe wait a bit to see if anyone else here has other suggestions.
2016-03-24 07:34 AM
2016-03-24 07:40 AM
Barry wrote:
I found another post where someone had the same problem.
It seems re-installing Archicad fixed it for them.
http://archicad-talk.graphisoft.com/viewtopic.php?t=49220
2016-03-24 07:51 AM
zeeyado wrote:Yes once installed successfully you can save for all devices.
but . I have question about this commond ...
can I export my project from this commond to
BIMx for (desktop - ipad - iphone....more) or no !
2016-03-24 08:10 AM
Barry wrote:thanks very much ...
You will have the 'Save as ... BIMx' option from the 3D window which is good for desktop and mobile devices and you will be able to 'Publish' a hyper-doc which can be viewed on mobile devices.
