problems uploading to bimx portal
Having problems uploading my files to he bimx portal
I don't know how to allow bimxuploader access to the web? any thoughts?
14 Replies 14
Csaba wrote:
Do you have a space or a special character in your username on the PC but not on the laptop? (Upload won't work until HF #4 if you have space or national character in your windows username)
My user details are shown in the previous image.
When I log in I use my e-mail which no spaces and only dots and '@' as special characters.
I use exactly the same details on both machines.
P.S. Just tried again from my laptop and now that didn't work either.
Intermittent problems are always the hardest to find.
Csaba Kezer
I'm sorry, I meant the username of your windows user account, not the BIMx login. If that contains a space or a special character, then the upload can't work right now.
However it is weird that the upload wouldn't work now from your laptop either. Would you mind sending your keyplug number and bimx email to the bimx [at] graphisoft [dot] com email? We will check if your settings are alright in our system.
Thanks,
Csaba
Csaba Kézér
VP, Global Customer Support
Details have been sent.
My problem has been solved and I can now upload to the BIMx website.
It seems there was a problem with my account setting which GS fixed.
So if anyone else is having upload problems send an e-mail to BIMx as suggested by Csaba.
Thanks Csaba.
Csaba wrote:
Hey Guys,
If you have upload issues please send an e-mail to bimx [at] graphisoft [dot] com with your registered BIMx email address and your WIBU/CodeMeter key number(s). Please also state that at which step do you get stuck and which error message appears? There might be an issue with some of your account settings what we would like to check out.
Regards,
Csaba
Katalin Borszeki
HI, here is one reason that could often cause the upload problem. Bimx17 desktop has to be hot fixed to min version (4005)
When you open BIMx, make sure that the opened BIMx version is the hot fixed build (min) 4005. In certain cases more BIMx versions might be present on your computer. If you are on a mac, the default application to open BIMx (upon double-clicking a BIMx file icon) might not be the latest build you have on the computer!! You can change this setting, if you select a BIMx file on your desktop and hit "commandI" (info) it will bring up the window on the screenshot below. Select build number 4005, and the uploading from BIMx desktop should go undisturbed. Thanks
Katalin Borszeki
Implementation Specialist
GRAPHISOFT
