Classification translation
bouhmidage
Hello,
i want to translate the Uniformat classification downladed from Archicad website,
the xml file, once loaded in excel, it can't be saved back as an xml to load it ino archicad,
Is there a way to translate it ? or workaround ?
Note : I have an excel sheet with only ID + translated classifications
Thanks
Archicad 25
Windows 10 professional
17 REPLIES 17
Try editing the XML file with a dedicated XML editor, like Notepad++ (it is free). Then, if you save changes, the XML files should still have the same format.
bouhmidage
i already tried this, , the problem is : how to translate only the classification names,
Archicad 25
Well, if you post a concrete example of what you are trying to achieve, I can take a look at it to see if I can find a way of doing it.
A screenshot or two would also be helpful.
bouhmidage
This Is the classification system, all in English, ( Masterfomat )
To translate names in frensh, to do this on archicad is a waste of time
translating the file in a XML editor will also translate commands
Archicad 25
OK, and what are you trying to do?
bouhmidage
translating classification names, from english to frensh
Archicad 25
bouhmidage
open file in excel => translate => save as XMl , don't work too
Archicad 25
And what if you simply save the XML under another name, and change the texts in the XML itself?
Looking at the XML, I would assume the simply changing the following
<Name>Procurement and Contracting Requirements</Name>
to
<Name>French Translation Text</Name>
should work.
Actually, I was curious so I tried it. I just modified the XML file in Notepad++, saved and I could import it into the Classification Manager Dialog without any problems.
As you can see, I have translated a few English entries into Hungarian and they are correctly displayed.
