I think you installed the BIM Server Manager application, but have not yet installed the BIM Server application itself.
You should do that.
On the machine where the BIM Server is located, the BIM Server Manager application is not really needed because a BIM Server Control Center is available from the Taskbar and you can open the BIM Server Manager from the BIM Server Control Center.
