Collaborate forum
RFA & RVT Geometry Exchange won't update
Gerald Hoffman
I have updated to the latest AC 24 update and the update dialogue indicates that my version of the RFA & RVT Geometry Exchange needs to be updated. It indicate the version is US 4000 and that the updated version is US 4015. I download the update and try to install it. The dialogue box indicates that I already have the RFA & RVT Geometry Exchange installed and doesn't have any place indicating that I can update the existing. I have to cancel.
I have tried deleting the RFA & RVT Geometry Exchange add-on out of the Add-Ons folder and try installing it but it still gives me the same message. Any suggestions would be appreciated.
Gerald
"The simplification of anything is always sensational" GKC
AC 25-4013 USA, CadImage Tools
2019 MacBook Pro 16" w/ AMD Radeon Pro 5600M GPU
OS X 11.6
2.4 Ghz 8 core i9, 64 GB RAM
27" LG 5K Monitor
runxel
Ace
Hi Gerald, you probably have the international add-on variant installed. It must be uninstalled before it can install the US version. There is an "Uninstall.RIO" in the AC24 folder for this.
Mostly AC 26 on Mac | Author of SelfGDL | Developer of the GDL plugin for Sublime Text |
«Furthermore, I consider that Carth... yearly releases must be destroyed»
Eduardo Rolon
You need to uninstall the previous Plugin. In your AC application folder double click "Uninstall.RIO" which will remove the previous version and then you can install the new one.
GS has "screwed" this one up. You are not updating and the instructions are not clear. Also if you have 2 versions of AC installed (US and INT like I have) then you need to uninstall it on both.
eduardo rolón AIA NCARB
Another of the forum moderators.
Macbook Pro M1 Max 64GB ram
OS X 10.XX latest
AC26 US/INT -> AC08
Puerto Rico, BVI, Miami
Vectorworks 2023
Gerald Hoffman
Thank you both for the quick and accurate solution to the problem. I didn't see the Uninstall.RIO folder in the main directory and probably wouldn't have recognized the RIO name anyway. Much appreciated.
Gerald
OS X 11.6
27" LG 5K Monitor
