Recently I have encountered problem with my .stl files. I made 3D models out of pointcloud, remesh it to good value of quality/speed (approx. size 1-2mb).
In ArchiCAD, it turns out, that it is a way too heavy. I have change it for window frame (it is only possibility to make it work in viewport). Too bad, it gives this bad-looking frame (even if I change material for AIR). Any ideas, how to make it work? Please see the attachment.
One of the forum moderators. Versions 6.5 to 27 Dell XPS- i7-6700 @ 3.4Ghz, 16GB ram, GeForce GTX 960 (2GB), Windows 10 Lenovo Thinkpad - i7-1270P 2.20 GHz, 32GB RAM, Nvidia T550, Windows 11
Barry,
Thank you for your response. I know this method, but this is modelled frame (appears in viewport when you highlight object). It won't go off after changes due to the render.
