2006-07-12 10:57 PM
2006-07-23 02:51 AM
2006-07-23 02:57 AM
2006-07-23 06:07 PM
sfriday wrote:sfriday:
David
Yeah I did that but ran into the problem that I talked about in my previous post.
I then ran into the problem of losing my dimensions if I moved or streched the image box that holds the axon view. If I explode the image box it turns all the colors to grayscale. SO I ended up exploding the dim. strings once I plugged in the correct measurements.
I am working in AC10 do you get the same problem?
Thanks for your time.
2006-07-24 06:44 AM
2006-07-24 05:38 PM
Ahhhhhh!
I see the light!
I was doing it the round about way of setting the axon like you did but I saved it as a view then imported it into the layout book then copied it to the detail window.
I like your way much better.
Thanks for your help.
