3D Import Problems
I am trying to import/ merge/ open as object - both a dwg and 3ds file with no luck at viewing the 3d elements. I tried with AC10 and AC9 with no luck.
Yet I can import the same files into Google SketchUp with no problem.
Whats the deal?
Am I not using the 3ds import add-on correctly?
14 REPLIES 14
David Larrew
What units are you using?
How far away from the project origin (0, 0, 0) are your 3D elements. ArchiCAD has a problem converting 3D geometry when it is too far from the project origin.
David Larrew, AIA, GDLA, GSRC
a r c h i S O L U T I O N S
WIN7-10/ OSX 10.15.7
AC 5.1-25 USA
The 3D elements are less that 30'-0" away in the Z direction.
Well I think I solved the problem (or got it to do what I wanted.)
In the latter versions you could view the model in the "Internal 3D" mode and save it off as a DWG. This would let you import the 3D view as lines and fills so you could easily put dim. on the axon or overlay the shadows (now fills) on a line drawn plan.
I still don't know if you can do that with AC10 but I was able to save the axon view in the navigator (now Organizer) while viewing it in "Internal 3D" mode.
I then loaded the view to the layout book and copied it from there back to the plan view to apply dim. (this allows you to click on each node of the axon.)
I then ran into the problem of losing my dimensions if I moved or streched the image box that holds the axon view. If I explode the image box it turns all the colors to grayscale. SO I ended up exploding the dim. strings once I plugged in the correct measurements.
CRAZY I know but couldn't figure out a better quicker way.
David Maudlin
sfriday:
A simpler way may be to create a blank detail window at the scale you want for the detail, generate the 3D view using the Hidden Line engine, use the "flat" version of the marquee tool to copy from the 3D window, then paste into the Detail window. You can then dimension and notate in this window and place it in a layout. This will work in ArchiCAD 9 or 10. This will not update from the model automatically, but neither does your current method.
HTH
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Thanks for the advice. I will give it a try. Maybe I can do it with shading too which is what I like.
Thanks Again.
Dwight
I'm no expert in the layout book (very happy with only 2 projects so far - no more epithet "Plotmaker: It's a PLOT!"), but what if a layout sheet had a published perspective view on it. Overlaid on top, you could annotate and dimension in 3D and also update the 3D.
Is this nuts?
Dwight Atkinson
David Maudlin
Thanks Again.
sfriday:
This will work with the Internal Engine Analytic Shading mode. In ArchiCAD 9, the shading color will be changed to the closest pen color. In ArchiCAD 10, a matching uneditable RGB color will be assigned to the fill.
Dwight wrote:
I'm no expert in the layout book but what if a layout sheet had a published perspective view on it. Overlaid on top, you could annotate and dimension in 3D and also update the 3D.
Dwight:
Nice lateral thinking. Unfortunately, the dimension tool (along with the other intelligent tools) is not available in the Layout environment.
David
Dwight
Yes.
I was thinking purely from a graphic viewpoint.
I didn't think it a problem since we can't dimension in 3D anyways without using the 3rd Dimension tool.
Dwight Atkinson
Dwight
3rd dimension tool - objexonlyne
Dwight Atkinson
David
Yeah I did that but ran into the problem that I talked about in my previous post.
I am working in AC10 do you get the same problem?
Thanks for your time.
Is objexonlyne a web site? How much is this addon?
Thanks
