3D cut away planes
For some reason I can no longer use 3D cut away planes. I can open it, but the 2d images do not show in the respective boxes. Any help will be appreciated.
Version?
I had this happen in 8.0 a few times, but never quite narrowed down what caused it. Haven't seen it in over a year. Clearing planes, closing the dialog, then re-opening usually fixed it.
One of the forum moderators
It is an 8.1 project that is having trouble. The problem seems to be project specific because I'm able to use cut-away on other 8.1 projects. closing and reopening the dialog box has not worked for me.
Thanks
