3ds 3dsmax
is there a difference? If so what?
thanks in advance, Cary
ArchiCAD 11 build 1114 usa full
windows XPsp2
5 REPLIES 5
3Ds max = 3D Studio Max (a.k.a '3D studio', 'Max', '3DS') = 3D modelling / rendering / animation software.
www.autodesk.com/3dsmax
.3DS = file format that can be used to transfer 3DS Max files between other users and other software (e.g Archicad)
.Max = 3DS max's native file format. harder to translate than .3DS.
However, www.3DS.com takes you to Dessault Systemes, how make Solidworks + Cartia among other things (more CAD software).
tom, thanks for your response.
I had simply assumed that 3ds was autodesk....and 3ds max was the new and improved AUTODESK
Your post clarifies why I found no 3ds mention at autodesk. So as happened recently someone requests a 3dsmax file what if anything do they not get from me by virtue of me "merely" forwarding a 3ds file?
windows XPsp2
You mean instead of sending them a .max file?
I'm not really sure sorry - as the .max file is the native file format it probably has a bit more information in it. To be honest I haven't touched the software for about 6 years, so I'm a bit vague on all the details.
thanks again....doesn't take much to confuse me. Cheers Cary
windows XPsp2
3DS was the original 3D Studio file format.
Originally the program was called 3D Studio.. Later a new version was released called 3D Studio Max, and with that version came the >max extension.. By that time .3ds had kinda become one of the standard export options,, bit like .dxf.
As I remember it went from autodesk to descreet then to autodesk???
