2012-12-07 02:31 AM
2012-12-07 02:41 AM
2012-12-07 02:53 AM
2012-12-07 03:21 AM
JMM4JMC wrote:It is added to your Archicad program folder but you will still have to add the library in your library manager or move it into the loaded Archicad Library if you use that as your default library.
But in 16 I read that the accessories library is automatically added.
2012-12-07 01:48 PM
...or move it into the loaded Archicad Library if you use that as your default library.Don't move it to the ArchiCAD Library, load it separately. If it is put in the ArchiCAD Library, it will get deleted when the ArchiCAD Library is updated.
2012-12-07 06:06 PM
2012-12-10 02:26 AM
David wrote:I should have said move it to the Archicad Library folder - which is where the Archicad Library is....or move it into the loaded Archicad Library if you use that as your default library.Don't move it to the ArchiCAD Library, load it separately. If it is put in the ArchiCAD Library, it will get deleted when the ArchiCAD Library is updated.
David
2013-07-02 06:45 PM
2013-07-03 04:02 PM
Dukatas wrote:Try loading the Accessories Library 17 via the Library Manager, it should be in the ArchiCAD 17 folder.
But when I load the accessories library the Interiors Accessories, dialog sill shows accessory parts not available.
