2008-08-13 08:00 AM
2008-08-14 01:37 AM
2008-08-14 04:34 AM
2008-08-14 05:04 AM
Matthew wrote:I have a copy of AutoCAD Light 2008, and I can insert PDF images into paperspace (layouts).
Does AutoCAD support PDF? I don't see any option for it in 2008. If it's new in 2009 then I assume AC doesn't support it yet.
2008-08-14 06:18 AM
Erika wrote:That sounds like a do-able solution. Thanks!
If you brought the pdf in from a module, when you save to dwg would that turn the pdf into an xref per the translator and solve the problem?
Not a great solution if you have a lot of pdfs
2008-08-15 04:33 PM
2008-08-15 06:12 PM
Djordje wrote:yes but in AC12 at least they are full resolution (300 dpi). I think this is a 10 issue.
AFAIK PDFs are converted to TIFF
2008-08-18 03:26 AM
Thomas wrote:Actually in AC11 (which is what I used), the problem occurred.Djordje wrote:yes but in AC12 at least they are full resolution (300 dpi). I think this is a 10 issue.
