AC23 problems with opening dwg/dxf
I started using AC23 and I have problems with opening dwg while in AC22 it's working. Apparently there is a problem in translator because when I was opening the dwg with translator from AC22 it worked. But when I opened it like external drawing it showed my dwg but when I wanted to transform to 2D elements it didn't work the file was empty. Does anyone has similar problem?
1 REPLY 1
Jp1138
Change the renovation status to see if the dwg it´s in the New state.
ARCHICAD 27 SPA
Windows 10
